This is a text-only command.
Type the text equivalent at the command prompt to add a Network
The SET WIDTH command lets you set the width for all new ispans in networks. After a new width is entered, the NETWORK WIDTH commend defaults directly into the NETADD command to allow immediate network construction.
To set a new network width, type NETWID at the command prompt, or select [Draw > Networks > Set Width] from the menu:
The prompt reads "Wall width [n]:". Type in a new wall width in drawing units and press ENTER; or specify a distance on the screen using the mouse.
The prompt reads "Pick existing wall [new]:". At this point, the command switches to the NETADD command [Draw > Networks > Add to]. Any spans you draw now will use the new width. If you wish to end the command at any point, right-click and choose Done from the Networks popup menu .
Text equivalent: NETWID
Related topics
