Networks:Change Width Span
This is a text-only command.
Type the text equivalent at the command prompt to add a Network
The CHANGE WIDTH SPAN command lets you change the width of a single span in a network.
To change the width of an existing span, select [Draw > Networks > Chg Wid Span] for the menu:
  1. The prompt reads "New Network Width:". Type in a new width in drawing units and press ENTER; or specify a distance on the screen using the mouse.
  2. The prompt reads "Network to modify:". Using the pick box, select the specific span you wish to modify.
CC3 immediately redraws the network, re-specifying the width of the targeted span.
  1. The prompt still reads "Wall to modify:". Using the pick box, you can continue to select spans set to the new width. Or to finish, right-click and select Done from the Netwroks popup menu .
Text equivalent: NETCWIDS
Related topics
