Networks:Change Width End
This is a text-only command.
Type the text equivalent at the command prompt to add a Network
The CHANGE WIDTH END command lets you change the width at a single span’s endpoint. A span can have different widths at each node, enabling you to create networks with a taper. The end width is the length measured at the endpoint, perpendicular to the direction of the span.
To change the end width of an existing span, select [Draw > Walls > Chg Wid End] from the menu:
  1. The prompt reads "New Network Width:". Type in a new width in drawing units and press ENTER; or specify a distance on the screen using the mouse.
  2. The prompt reads "Network to modify:". Using the pick box, select the specific span near the endpoint you wish to modify.
CC3 immediately redraws the network, re-specifying the end width of the targeted span.
  1. The prompt still reads "Network to modify:". Using the pick box, you can continue to select spans, modifying their chosen endpoint widths. Or to finish, right-click and select Done from the Networks popup menu .
Text equivalent: NETWIDE
Related topics
