This is a text-only command.
Type the text equivalent at the command prompt to add a Network
The CHANGE WALL WIDTH command lets you to change the width of an entire network. Every span in the network will have its width reset to the width you specify.
Be careful when using this command with network systems where you have created spans of varying thickness. CHANGE WIDTH ALL will instantly reset those widths to the new value. If this happens, use the UNDO command to restore your drawing.
To set a wall network to specified width, select [Draw > Networks > Chg Wid All] from the menu:
The prompt reads "New Network Width:". Type in a new width in drawing units and press ENTER; or specify a distance on the screen using the mouse.
The prompt reads "Wall to modify:". Using the pick box, select any point on a wall network.
CC3 immediately redraws the network using the specified width.
The prompt reads "Pick existing network [new]:". At this point, the command switches to the WLADD command [Draw > Networks > Add to]. Any spans you draw now use the width last specified with the Set Width command.
If you wish to quit at any time, right-click and choose Done from the Networks popup menu .
Text equivalent: WCWIDA
Related topics
