Right-click Circle to draw an ellipse.
· An ellipse has a major axis and a minor axis. You can draw ellipses at any angle. The angle of the major axis is called the inclination of the ellipse.
· CC3 remembers the center of each circle, arc, or ellipse you draw and offers it as a default or prior value the next time you draw an ellipse during the same work session. This feature lets you draw concentric ellipses. Right-click to accept the default or prior, or enter a different value as explained under the individual ellipse commands.
· To change an ellipse’s radius, use EDIT (), DYNAMIC EDIT (
), or STRETCH (Edit > Stretch).
Ellipse types:
Center and Inclination(Text-only command)
Elliptical Arc(Text-only command)
Circle at Angle to Window(Text-only command)
