Change Text
This is a text-only command.
Type the text equivalent at the command prompt to change the highlight color.
CHANGE TEXT TO changes selected text entities to the entered text. Use this command to change multiple, existing text entities to the same text. Each changed entity keeps its own location and properties.
  1. CC3 displays the Text dialog box. Type in the new text. For longer text, you may check the Muilti-line option. Choose the OK button when done.
  2. Select text entities to modify using the Entity Selection dialog box. When you select OK Do it, CC3 changes all selected text to the new value.
To change a single text entity to a new value, you can also use the EDIT command [Edit > Edit].
To change any text metrics or properties of an existing text entity, use the CHANGE-TEXT PROPERTIES command [Edit > Change > Text Properties].
Text equivalent: CHANGETX or CHANGEX
Related topics
Replace Text
