Replace Text
On the Edit menu, click Text to access Replace Text.
Replace Text lets you change any text contained within a text string or even whole text strings. You can also use this to select any text in the drawing that contains a certain string.
  1. Select the text which you want REPLACE TEXT to search
  2. Set the dialog box options.
  3. Select Replace One or Replace All.
Replace Text dialog box.
Find: Type the text string you want to match.
Replace: Type the text string with which you want to replace the "Find" string.
Match:
All: matches only complete text.
Part: matches any text containing the Find text.
Begininning: matches any text the starts with the Find text.
Ignore Case. the Find text ignores whether letters are upper or lower case.
Prompt: prompt will show a crosshairs at the selected text and ask if you wish to replace it, then move on to the next text.
Replace One: replaces the first found instance of the Find text.
Replace All: replaces all instances of the Find text.
Text equivalent: TREPLACE
Related topic
Edit Text
