Right click Change Properties
to select ChangeLine Width.
CHANGE LINE WIDTH changes the width property of selected entities. Each entity possesses a line width property that is set at the time the entity is created.
Select entities to modify.
CC3 automatically displays the Change Line Width dialog box. At the prompt "Change line width to:", type in the desired line width and choose the OK button.
CC3 redraws the entity with the new line width, and the command terminates.
Important: Use of this command does not change the current line width. Note that the "W:" setting on the Status Bar does not change. Click the line width indicator to set the line width for new entities.
Text equivalent: CHANGELW
Related topics
