Send Behind
Click Send Behind image\BEHIND.gif to put entities underneath a selected entity.
SEND BEHIND works like the BACK command, drawing selected entities at the back of your screen. SEND BEHIND is different in that it "moves" the selected entities behind specifically selected entities. BACK moves the selected entities to draw behind all other entities in the drawing.
  1. The prompt reads "Move above entity:". Pick one entity that the selected entities will move behind.
  2. The prompt reads "Select entities:". Use the standard entity selection procedure to select one or more entities to be moved behind the previously selected entity.
Use UNDO to reverse the operation.
Text equivalent: BELOW
Related topics
