Click Bring In Front Of
to bring entities on top of a selected entity.
BRING IN FRONT OF works like the FRONT command, drawing selected entities at the front of your screen. BRING IN FRONT OF is different in that it "moves" the selected entities in front of specifically selected entities. FRONT moves the selected entities to draw in front of all other entities in the drawing.
Its main use is to insert new symbols into mountain ranges or forests.
The prompt reads "Move above entity:". Pick one entity that the entities will move in front of.
The prompt reads "Select entities:". Use the standard entity selection procedure to select one or more entities to be moved in front of the previously selected entity.
Use UNDO to reverse the operation.
Text equivalent: ABOVE
Related topics
