Text-Only Text commands
Some Text commands are only available as text-only commands. Type the text equivalent at the command prompt.
TEXML
This is like the standard text command except it opens with multiline on.
TFIND
Trying to find text in the drawing? TFIND will allow you to search for text and parts of text. The result is displayed in dialog box where you can zoom to a text or select all found text.
Text search can be performed on a whole text string, part of a text string or the beginning of a text. There are options to ignore case sensitivity and to restrain only to visible texts. If not 'Only visible' is checked all text will be searched. Please remember that a multiline text is one text and you will need to search for part of string to be able to find a line in that string.
The search result is presented in a dialog box. Only the 256 first entries will be displayed. The text, layer name and position are displayed.
The View button will move the zoom center to the origin of the text, without changing visible layers or magnifying factor. The OK button selects all found texts. These can then be selected by Prior. This allows you to select entities which contains a certian text string.
TEXEDIT,TEXCOPY
These commands use one piece of text as an original and allows to modify the text and then place it just as you would do with the TEXT command. After selecting the text to copy settings from, the normal text dialog is displayed. You can modify the text as well as text properties. TEXCOPY keeps the original text, while TEXEDIT erases the text.
Right clicking when asked for position with TEXEDIT will place the text at its original location and terminate the command.
TEXPLODE
This is explodes text into Paths and B-Splines, then groups them.It is the same as EXPLODE TEXT, except that it groups entities instead of making the text into a multipoly.
