Always calculate colors from current color
If you select this option, the color of your solid objects will be based on the current selected drawing color. The other colors in the scheme will be selected from either side of the color on the color palette. If there is no sufficiently dark color, black will be substituted, if no light color then white will be used. The first 32 colors on the color palette do not form shades of color around a fixed color, so don’t use these colors when this setting is on.
