Double Arrow
Right click on Line image\LINE.gif, Path image\PATH.gif or Smooth Path image\SPLINE.gif, to select entities with arrows on.
DOUBLE ARROWS draws entities just like the ARROWS, except that it has arrowheads on both ends.
·   The arrowhead shape and size are determined by ARROWHEAD STYLE (Specs > Arrowhead Style);
·   Only one style of arrowhead can be used in a drawing.
·   The arrowhead style is independent from arrowheads used in dimensions.
·   You can create notes by combining DOUBLE ARROW entities with text entities.
Path Double Arrow
  1. Select the first point. Use the crosshairs and left button or type numeric coordinates.
  2. Select the next node point on the arrow. Continue selecting nodes until you press the right button to end the arrow.
Text equivalent: PATHDA
Line Double Arrow
  1. Select the first point. Use the crosshairs and left button or, type numeric coordinates.
  2. Select the next point to draw the line. You can continue to draw a series of connected line arrows until you press the right button to end the arrow.
Text equivalent: LINEDA
Arc Double Arrow
  2. Select the 2nd and 3rd points of the arc in the same manner as you selected the 1st point. .
Text equivalent: ARCDA
Smooth Path Double Arrow
  2. Select the next point. Continue selecting nodes until you press the right button to end the arrow.
Text equivalent: SPLINEDA
