Arrows
Right click on Line image\LINE.gif, Path image\PATH.gif, Arc image\ARCB.gif or Smooth Path image\SPLINE.gif, to select entities with arrows on.
The ARROWS commands draw entities (paths, arcs, or splines) with an arrowhead at the first node point. Please keep in mind the following:
·   The arrowhead shape and size are determined by ARROWHEAD STYLE (Tools > Set Properties > Arrow Style);
·   Only one style of arrowhead can be used in a drawing.
·   The arrowhead style is independent from arrowheads used in dimensions.
·   You can create notes by combining ARROW entities with text entities.
Path Arrow (Bends)
  1. Select the first point. Use the crosshairs and left button, or type numeric coordinates.
  2. Select the next node point on the arrow. Continue selecting nodes until you press the right button to end the arrow.
Text equivalent: PATHA
Line Arrow (Single)
  2. Select the next point to draw the line. You can continue to draw a series of connected line arrows until you press the right button to end the arrow.
Text equivalent: LINEA
Arc Arrow (to End)
  1. Select the center point. Use the crosshairs and left button, or type numeric coordinates.
  2. Select the 2nd and 3rd points of the arc in the same manner as you selected the 1st point. The arrow will appear on the 3rd point, at the end of the arc.
Text equivalent: ARCA
Arc Arrow (from Start)
  2. Select the 2nd and 3rd points of the arc in the same manner as you selected the 1st point. The arrow will appear on the 2nd point, at the start of the arc.
Text equivalent: ARCAS
Smooth Line Arrow
  2. Select the next point Continue selecting nodes until you press the right button to end the arrow.
Text equivalent: SPLINEA
