To draw a point, select Point on the Draw menu.
POINT draws a single dot (one pixel). Points are usually used as temporary reference markers that you hide or remove when your drawing is complete. Points can also be used for shading in certain symbol libraries (see the basic dungeon symbols catalog). They can also be used to make sure that sheets do not disappear when you save a drawing.
The prompt reads "point at:" Use the crosshairs and left button or type numeric coordinates to select a location for the point.
After drawing the point, CC3 lets you draw a series of points without re-selecting the command. Right-click to stop drawing points.
Please note: On some high-resolution displays, a single pixel is very small and may be difficult to see using certain background color and entity color combinations.
Text equivalent: POINT
