Grid Size
Grid spacing. This is the distance between sides (not vertices) of the hexes or squares. (If you want to use the distance between vertices, enter that distance and type /1.1546936 straight after the number. CC3 will do the division for you.)
Even columns are higher: This causes the top of the second column in hex grids to be higher than the top of the first column.
