Roof Colors
image\roof_colors.gif Click on the color to select a color from the color dialog box. If you uncheck the "Use three color scheme" check box, only two colors will be used on your roofs. The flat roof color is only relevant if you are using the flat roof type. Click here for more informationimage\buttonarrow.gif
