Insert Node
Click Insert Node image\INSNODE.gif to add a node to an entity.
The prompt reads "Insert node at:". Select a point on the entity you wish to modify. Select a point for the new node. The endpoints of the original entity stay in place, and CC3 draws two new segments from the endpoints to the new point. Paths, wide paths, polygons, wide polys, and splines can have a maximum of 508 nodes.
Text equivalent: INSNODE
Delete Node (image\DELNODE.gif)
The prompt reads "Delete node at:". Select a point on the entity near the node you wish to delete. The node is deleted and a new segment drawn between the two previously adjoining nodes. Paths, wide paths, polygons, wide polys, and splines must have at least two nodes.
Text equivalent: DELNODE
