Click Delete Node
to delete a node from an entity.
The prompt reads "Delete node at:". Select a point on the entity near the node you wish to delete. The node is deleted and a new segment drawn between the two previously adjoining nodes. Paths, wide paths, polygons, wide polys, and splines must have at least two nodes.
Text equivalent: DELNODE
