Remove Nodes
Right-click Fractalize {frx.bmp} to access Remove Nodes.
REMOVE NODES reduces the number of nodes in a path or polygon. It is usually used to reduce the depth of a previously drawn fractal or Freehand Sketchl, to speed redraws. If you are combining maps to make a smaller scale map, you will probably want to reduce the fractal depth on each fractal.
