Right click Extract Properties and select Draw Like from the menu.
Draw Like enables you to draw an entity based on another entitiy. When you select the entitiy, it extracts the entities properties and starts a drawing command. For example, if you selected a piece of text, you'd be able to add another piece of text to the drawing with the same properties.
You can change the drawing method CC3 uses with Draw Like Settings.
