Right click Circle to add a Donut to your drawing.
The DONUT command builds a 2-circle multipoly. The multipoly will automatically fill with the current fill style.
To draw a donut select Draw > Circles > Donut:
The prompt reads "Inner diameter[n]:". Specify the diameter of the inner circle (donut hole). Right-click to accept the default value or type a value and press ENTER.
The prompt reads "Outer diameter[n]:". Specify the diameter of the outside circle of the donut. Right-click to accept the default value or type a value and press ENTER.
The prompt reads "Center:". Use the on-screen cursor to pick a center or type numeric coordinates.
CC3 draws the donut, hatching it with the current fill style, and then terminates the command.
Donut Tip
Donuts are ideal fare for gamers. In CC3 they can be used to create round towers with solid walls.
Text equivalent: DONUT
