Double Lines
Right click image\LINE.gif to add a Double Line to your drawing.
The DOUBLE LINES commands draws double lines separated (or offset) by a specified distance. It can be used for corridors, roads within cities and double-edged coastlines.
  1. The prompt reads "Separation [n]:". Separation is the distance between the double lines. Right-click or press ENTER to accept the default. Type a new value in units, feet and inches, etc., or use the left mouse button to drag the cursor, specifying a distance on the screen.
  2. Now the prompt reads "Next point:". Select the next point, using the new anchor as the "rubber-band cursor". Right-click to complete or end the command. Left-click to begin another double line.
Text equivalent: DBLN
