Map of the Month
Forum member Nicholas Hopkins created an atmospheric floorplan for a Call of Cthulhu game.  Download the PDF.
He says:
I saw a couple of floorplans in some older mission sourcebooks for Call of Cthulhu and wanted to emulate it as much as possible. I am doing a 1920′s campaign so I wanted it to look a little old fashioned, hence the black and white. It is based on the lighted dungeon template so that the shadows fall the right direction and it gives the rooms a little more texture as there are small, subtle shadows towards the corners of the rooms.
I used the Sepia setting under the RGB Matrix effect and it worked very nicely. Because I didn’t want a background of solid black (never seems to print well) I put in a couple of light sources outside the walls to light things slightly and cast some shadows off the corners of the building. There was some odd effects with the light sources associated with doors and windows so I just made a new sheet called Window Block, made sure that things on it blocked the light sources and was below the Wall sheet so it would disappear, and drew a simple line across the openings. Took care of things nicely. The symbols are a mixture of DD3 symbols and SS3 Modern symbols. They all came out nice looking with the effects turned on.
Share
One Response to “Map of the Month”
  1. I love this map! It has great atmosphere, but is still really useful as a map — the labels are clear, the furnishings can be seen, and it’s possible to see how the stairs in the middle hallway curve down into the shadows.
    Wonderfully done.
    Steve
    [Reply]
Leave a Reply
