Perspectives Pro includes some solid entities to create platforms, stairs, balconies, towers and holes. The appearance of a solid is determined by the current Perspectives Settings
. Cylinders, 3D Boxes (correctly known as a right parallelepipeds) and 3D Polys (a polygon, extruded vertically) are all available.
After you’ve drawn the base of a solid, you are asked for its height – if you select a point above the base, you will get a solid, if you select a point below the base, a hole.
Other solids are available, but these are currently beta versions. They do not hatch properly. Type in their text equivalents to use them – but remember they are betas. We recommend that you use them with a Perspective Setting that does not have a hatch pattern (for example, Current Color, Solid)
Solid |
Text Equivalent |
Pyramid |
IPYRAMID |
Cone |
ICONE |
Sphere |
ISPHERE |
Spherical section |
ISPHERA |
Rectangular-based slope |
IBOXA |
