Perspectives Pro is an add-on for CC3 that allows you to create isometric floorplans. It has a wide range of symbols, similar to those in Dungeon Designer 2. There are four versions of each freestanding symbol, one for each cardinal direction. There is only one version of each Wall Feature symbol – these front-on views are "sheared" so that they align to any wall.
You can draw a top-down 2D view of your floorplan or take an existing 2D drawing, then convert it into a perspective view by projecting it.
· You can draw floors, walls and rooms (floors and rooms) directly in isometric view.
· You can add solids (cones, cylinders, 3D boxes and polys) in a vertical orientation.
· You can make vertical holes by adding a solid with a negative depth.
· You can give flat objects depth by extruding them.
· You can control the appearance of surfaces using predefined settings, or create your own.
· You can create your own Perspectives symbols.
Perspectives Pro is not truly 3D – it has certain limitations.
