A Regular Poly Floor lets you add a polygonal area in the current floor hatch style in Perspective view.
To add a Regular Poly Floor
1 On the Perspectives toolbar right-click Rectangular Floor
, then click Regular Poly Floor.
The prompt reads "Number of nodes[n]"
2 This determines the number of corners on the polygon. Right-click to accept the default or prior number of sides, or type a new value (for example, type "4" and press ENTER to draw a square).
The prompt reads "Center[x,y]":
3 Right-click to accept the default or prior center or click a center point
CC3 displays a dynamic cursor anchored to the center of the entity. A radial cursor marks the 1st corner. The prompt reads "1st corner (or enter distance):".
4 Click a point, or type a distance then press ENTER.
Distances: All distances entered in the command are isometric.
Note: If the current Perspective Setting has the Align to First Edge for floor hatching selected, the hatch style will align to the first two points you select.
