This shortcut draws a gray (color 14) path on the ROADS 1 layer, with Solid line style and fill style, with the current line width.
Reshape and adjust your road using the options under path.
Set the width for new roads using the Road Width icon, or using the Line Width indicator.
You can draw roads using other CC3 entities; just select STRAIGHT ROAD, right click to cancel the road, then select another drawing command.
Text equivalent: CITYROAD
