Right click Change Properties
to select Change Color.
CHANGE COLOR changes the color of entities.
Select entities to modify.
The prompt reads "New entity color:". To select a new color:
· Pick a different color from the Color Bar;
· Right-click to display the 256-color palette, from which you can pick a new color and choose the OK button;
· Type a color number and press ENTER.
· Select the LIKE icon ((bmc LIKE.BMP})then select an entity with the color you want.
CC3 redraws the entity in the selected color.
Important: Selecting a color in the CHANGE COLOR command doesn’t change the default color for new entities. Click the color indicator to set the color for new entities.
Text equivalent: CHANGEC
